H
HPJUNKIE
Wondering if anyone has played with the stk skid on a '07 Summit to build in initial sag like Holz recommends with their kits. Had a Holz on my Edge & Cat chassis in the past & worked well to keep the track on the ground. Wondering if anyone had installed say, 2" drop brkts & moved say, rear lower arm fwd 1'. How about a progressive mounting/pivot block at the front of the rear coil springs? Allows to set up with an initial lower rate & rise as susp is compressed? Your thoughts?
