I picked up a '14 kit over the summer and I've got it mounted up on my bike but have some finishing touches I need to work out. Hoping I can find some wisdom on here as the search brings up loads of useless info.
Carb heater ... I need one
Is the KTM electric enough ? I ride in central Idaho in the sawtooth's and it's pretty dry. I've never used a heated carb on my sleds but bike might be a little tricky. I like the electric as I can leave it in place for summer riding.
T-stat ... need on of those too , maybe?
My kit has a tunnel cooler in it and I'm leaning toward using it how ever is there a reason to stay with the radiators? I was going to run a KTM 990 T-stat as it's 175 degrees and has a bypass for heated bars or carb heat if the electric is not enough... not to mention they are 32 dollars.
Pre filter ... what are you guys using on the '14 style 300's ? I can't find anything other than universal stuff. My bike is a '14 Husaberg TE300 , pretty much a Husqvarna TE300 with pds or a 300 XC-w
Jetting... I know I need to rejet richer for temp but how much do you guys have to fiddle with the carbs on the 2 stroke snowbikes? The bike rides great from 6,000 to 9,000 in the summer and this is the same range I'll be flogging it in the winter.
Extra fuel .... I have the rails for the mountain addiction can but since they are 85 bucks I fabbed up a quick rack for a 2.5 gallon can I had laying around. How does your fuel consumption compare to the 4 strokes?
