the m sleds are quite a bit heavier on the left side. as a result, i find it much easier to turn and carve to the left than the right. the other day i picked up the back end of my sled, and noticed that as the front end took more of the load, the front suspension dipped even further to the left. i figure its time that i try doing something about it, and i'm wondering if anyone else has tried anything similar, and what results they got.
in a perfect world, i'd like to balance out the wieght better, but i don't think thats gonna happen. so, i was thinking of either stiffening up the left side spring, softening up the right side spring, or doing a little bit of both. and by spring in my case, i mean adjusting air pressure in the floats.
a little side question about the floats: i don't have the little hand pump. is it possible to adjust pressures with my compressor and a tire gauge, (if i can make them fit on the valve) or do i run the risk of damaging the shock?
