So I got my Husky a couple of weeks ago, took it for a test ride on a trail and some gravel roads, everything seems fine. So started to convert, attached a 15 TS LT and that fit fine. Now I have some questions on how to proceed.
Gearing now is 13 on the counter shaft and TS all 17, is this acceptable combination?
Fork springs, I asked the dealer to look into getting me .64kg/mm, not likely that they would be able to get them. What forks would work for my set up (im ~200lb), I would like to not revalve if possible? Where is a good place to get forks? Should I leave the oil that is in there or go with a heavier weight?
Air box, my plan was to get a unoiled filter and put a prefilter over it, see how that works.
Anyone have a good solution for pipe sheld? The dealer had a small 4 inch piece for like 80 bucks seems to be tool small.
I saw in an old thread someone had links to some kevlar fabric for engine shroud, but it kinda ended abruptly. Anyone make engine covers that work, looking for diy solution.
Thanks again, this forum has been a wealth of knowledge.
Here it is a work in progress.
