Setting TPS and PCV
Hello, I just reset my tps on my 2011 800. Set the base a .7v and turned idle screw to .94 and the sled idles just like it should but when i crack the throttle wide open the voltage only read 4.10V In the manual its supposed to read 4.30V. What could this be? My throttle is set properly and so is the freeplay. Will this create an issue? Any ideas? I synch'd the PCV tps setting to match the idle voltage and the wot voltage and im getting 100% wot on the pcv. Sleds just not pulling Wot no matter what im doing. Hits 8000 and thats it. Plugs are also realy rich and black at wot. Thanks!!
Do you have stock grips? Some people have corked their bars using cork that was too thick which didn't allow full travel on the throttle lever
