Setting the TPS
Is there anybody in the Bozeman area that could help me set my TPS or help to figure out why it won't idle? I'm leaning towards the TPS because it runs great with a little bit of gas and compression is good. I am hesitating on taking it to the dealer because I have not had some good experiences with them. Thanks
It could just be a matter of turning up the idle a bit at the throttle bodies instead of adjusting the tps. Make sure you are adjusting the idle set screw and not the synchronization screw. You should idle at 1700 rpm plus or minus 200. See attachment for idle screw location.
