2016 YZ No valving changes It washes out on side hills in the powder way more than before. Im thinking leghtening the strut might help.On what bike? Valving also? Washing out when and where... what conditions..
Sent from my SM-F900U using Tapatalk
The stiffer front end helps keep the weight more neutral, so you're likely not getting the ski to hold as much as you're used to. I tend to compensate with my body position and riding style.
However if you're on a 2016, I'd suggest looking at the aro ski/spindle combo. The aro ski holds much better, especially with a 137 pushing it around.
When you jam on the throttle hard or just keeping a constant throttle? My guess would be to raise the forks up towards the handle bars ( or lengthen the strut) to weight the front more. With the new springs your front end is sitting higher changing the geometry a bit and has lightened the front up...2016 YZ No valving changes It washes out on side hills in the powder way more than before. Im thinking leghtening the strut might help.
