Ok, this may be a stupid question but I have to ask it. Can the shocks on a 2004 1M be serviced (oil and nitrogen added) without removing them from the sled?
Can you explain why they can't?
Had my shocks redone at Tom's Snowmobiles Sierra City Ca. Replaced most of the internals with Fox stuff (the shocks are exactly the same). he did an awsome job and in my opinion my shocks are better now then when they were new, however I hvn't rode the sled with them on yet, but they definately feel better and have better/smoother rebound.
I personally would not heat a shock, may not be so good for the o-rings.
To really srvice the shock all new internals should be changed. For the cost of the o-rings, wear strips etc. it's worth it. If the o-rings aren't perfect water/ air gets in and the shock works like poo after a couple rides.
Other factors are piston depths etc. when re-assembling. They need to be correct or the shock won't work right. Too much oil and the shock won't stroke all the way, too little and no dampening.
