Hey DLish, I haven't read your other posts about your problem, but reading this one gave me a few ideas for you to try out...
1. Check your weights for free swing, if you take your belt out and compress the clutch a bit, you should be able to move your weights with ease, if you just put new weights in with the speedwerx clutch kit, you could have one or more over-tightened and thus they would not swing easily. Also check that your rollers spin smoothly and don't have any flat spots.
2. Check that your oil pump is not sticking open and over oiling when you let off the throttle, mine does this every once in a while and it bogs when I hit the throttle. Best way to check is to unhook the linkage from undernieth by removing the belly pan and cycle the oil pump open and closed and see if it wants to hang up anywhere.
3. You don't want to hear this, but try putting the stock can back on and see what it does, just seems like the 7 likes the stock can the best, unfortunaly it weighs a ton and makes the sled sound like a sewing machine...lol.
4. Check the bushings in both your cluches, you just don't want to have excess play in the movables from worn bushings.
5. Just FYI it's been my understanding that the ethanol plug adds like 5% fuel to the whole map (not timing) so that's why it runs so fat unplugged, even with ethanol enriched fuel, my sled runs like crap with it unplugged, the '05s seem to be fat enough to run ethanol enriched fuel with the plug still connected.
6. Another thought, it seems that I have read about more than a few people that have had a bog in the low end and have put a fuel pressure regulator in tank and actually reduced fuel pressure and been able to get rid of the bog and have better all around runability, something you could try if everything else seems to check out, just watch your plugs/piston wash.
To the guy with the M8 with the bad roller, get ahold of freeagent on here, or better known as Oregon Trail Powersports and get your self a new primary cluch with a new spring and weights, it will probably cost you around $400ish but it will be a really good tune up for a sled with a few thousand miles on it. It's just a better option than only replacing the spider assembly. I just put one on my M7 cuz I had a smoked roller and threw a weight when the bolt broke, it made it a whole new sled.
Hope this helps you guys out, keep us posted on what you find and hopefully it will help others!
