M8Matt, at the end of your video you said something about ratcheting the day before and you thought your belt was gonna go. Did you mean track?
I've been checking my QD belt from the beginning and proved to myself it is not the brake that causes the heat at the top sprocket. But, if you do brake hard for a long time (like playing snowcross) it really doesn't add too much more heat to the belt while moving. It just adds a longer cool-off time (because of more mass) when stopped to the top sprocket (five handfulls of snow instead of three LOL).
IMO, if heat is an issue to this belt compound (they are shearing not delamb though), it is happening while sitting still. A plastic-rubber engineer would need to come in with some info here.
Another thing that happened to mine (but no others have noted this so,,,) is the top pulley bolt came loose twice . It didn't fall out it just lost it's torque. 3rd time I used high heat green and torqued to 35 ftlbs. That has stayed tight for 400miles.
I would not have found this had I not spun the drive line (to check sprocket run out) using the top sprocket bolt. I checked it again 75 miles later and it became "just loose" again (using blue locktite and 29ftlbs) and this time noted the washer had worn the coating off the sprocket so maybe the bolt was not backing out but the sprocket surface wearing.
Has anybody that has had to remove there belt noted the fit of the top sprocket to shaft? Is it wobbly-loose when slid on by itself? Maybe mine is just different.
Best sled I have ever owned to date but I'm a little anal about checking things 'cause I go out on my own too much so I develope "habits".
I had to chuckle to myself the other day. Out with a bunch of friends for a "Sunday" ride (you know poking at hills then sitting and talking about it) and when I got to the "gathering" I opened the exhaust side and grabbed a handful of snow to jam onto the top pulley.
My buds said WTF, did they move the clutches over lol. For years while riding Doo's and Cat's, I have been like the rest and opened up the clutch cover to let things cool. In less than a half of a season my habit changed.
I don't need to worry about the clutch belt anymore lol. Now I cool my QD belt. Oh well, at least I still open something lol.
