2013 RMK Pro 800 with Silber Turbo. Running 30% 100LL with 91 at 3psi 1000 elevation.
About 200 miles on a top end refresh and about 1 mile down the trail at 110˚ engine temp very light throttle and seized the motor. Turned the clutch and it came back rode it back tot the trailer. Pulled it apart and found this. Is this an oil pump failure was I starting to lose a crank bearing and it took the piston out also. PTO side was toast mag side was decent but not perfect.
There was a crazy dark pasty coating all over everything throughout the PTO side of the case and piston. Both spark plugs also looked to have a lot of aluminum on them.
Intake side took most of the damage.
Thanks, Cory
![IMG_4710.JPG IMG_4710.JPG](https://www.snowest.com/forum/data/attachments/345/345557-717f9822561949e5dfdd09ae208fb14f.jpg)
![IMG_4712.JPG IMG_4712.JPG](https://www.snowest.com/forum/data/attachments/345/345558-d0b15a3cbadc64bae7aee7586fbf4157.jpg)
![IMG_4713.JPG IMG_4713.JPG](https://www.snowest.com/forum/data/attachments/345/345559-adea9ab5136b0f4e296c788dbd2b7224.jpg)
Thanks, Cory
