Nick, that is part of the reason I wanted you to call me, was to explain that my tail pipe was missing. It wasn't like that before when we were tuning. I had it off and forgot to put it back on before dropping my sled at Dobeck. I do have some ideas for the code that I wanted to run by you. Give me a call whenever is convenient for you.
Everyone else, thanks for the info.
Nick and I are working on the base program of my Dobeck box. We have been adding boost fuel to the primaries and then having the secondaries kick in at 5 psi. It has been giving us a bog when the secondaries turn on. We are going to try a program similar to Twisted's where there is no boost fuel added to the primaries and the secondaries turn on at 1.5 lbs. A lot like a Boost-It box. My buddy is running the Twisted program and his is boggy off the very bottom. I was wondering if it is not because the secondaries are turning on too soon. I thought maybe we should try turning them on a little later, like at 2-3 psi. I don't know if the there is a chance of running lean then without any added boost fuel at those low boost levels. Anyone have any thoughts or opinions?
