2001 xc sp edge factory snow x sled, Cr tunnled and longtracked. I have owned since new... how much play should the secondary clutch have on the jack shaft. there are 3 spacers on the back side of it, and at least 8-10 washers on the frnt side, how much play is acceptable? I would say it has 5mm's of play across the shaft,, took the clutch off to fix broken bolt then upon install noticed the play,,, i would assume it has had this much play since new. dose this sound like a safe tolerance.
