Secondary balance dots???
fasta76
Dumb Question!!
I pulled apart my secondary to clean and put new rollers in! I forgot to mark witch way it went for the balancing?? Should i line up the balance dots so the are accross from each other? Or should i put one section of dots on the bottom and the other on top? I know "Rookie" mistake!!!
On the older ones there is a line. On the D/D there is a d/d logo that should be across from each other when its back together properly. Not a rookie mistake either lots dont even know they are marked.
I knew to mark them with a sharpie but i had a brain fart!! What year would have the marks? I have an 07 M8
I did the same thing. I called BDX and they told me to line up the diamonds that are cast into the outside of the sheaves. I figured if anybody knew they would.
What will happen the D/D symbols are not lined up? I don't think mine are lined up.
