i believe the only dragon seat hat will fit are from the 07-08 dragons..the new ones have a smaller tank so they will not..
i will send you a link to one that "was" for sale (PM)
The story I heard from a post a long time ago was that the new support can be used in place of the plastic base, but you have to un-staple the rear of the seat cover in order to secure the nuts on the bolts through the plastic seat frame, then re-staple the seat cover at the back.
I don't know where that old post was from, but it was a while ago.....
BINGO...pretty sure that post was form me..its VERY easy to do...you can use ANY seat post..OEM or SKINZ...but the OEM one has a wider base and 4 holes to mount to tunnel vs SKINZ 2..so i would get the OEM one IMO...
DO IT!!!
Very possible... couldn't remember for sure.
I have thought about doing this mod myself, but I don't like how the tank hangs out from under the rear half of the seat compared to the newer shaped tanks... just not as clean a look at the rear 3" of the tank as the newer ones IMO....
damn..i was close...
i cant be perfect all the time SETH....
so.....................I can use my seat and any OEM seat post?
and............if I decide to get a different seat it would need to be a 05 - 07 seat only to match my tank?
Sean.......I need pictures again buddy. What did you use and what does it look like?
The Rivnuts are a great invention.
But, IMO, with only the hook in front, the rear 2 fasteners are the sole support for the seat movement. If you take a hard side impact or land hard on the seat the rivnuts will, IMO, pull out of the plastic base... a backup plate like they used in the 2007 seats (same seat basically as the 2005/06) distributes the load over a larger area.
For most situations the riv-nut will hold... It is only the more demanding ones where they would tear out.
Just my 2 cents and not at all knocking the great ingenuity of AngerManagment... Great Idea!!
Wondering where you got that peice of rubber that goes over your cooler in the pic?
Thanks
