Scratcher Mount's
Status
Not open for further replies.
summitbound
I seen somewhere you can change the front Idler Mount and run Scratcher's behind the wheel ??? Anyone Know who sell's them
Remove the front idler and its bracket. Re-drill the hole to accept the bolt for the scratcher and drill another hole for the "tail" of the scratcher. Or if you want to keep the idler in place, just remove the wheel and drill a hole for the "tail" far enough from the center of the wheel to keep it from rubbing on the spring of the scratcher. Then measure and drill the hole for the bolt, install scratcher and reinstall wheel.
Status
