Y
Yamamauler
Looking for some idea's and help tracking down a stutter issue on my Apex.
The sled is a 2007 MPI stage 1 Apex with under tunnel exhaust.
After warming up the sled and heading out the sled runs great, once the motor starts pulling hard around 8,000 or higher then the slowing down I get a bad stutter from 2,600 - 5,000 rpm's and generally runs like crap. Stop and the sled will not idle.
Hit the kill switch or turn the off and restart the sled and it runs great until it starts pulling hard or hitting around 8,000 then above issue repeats.
Before re-setting it feels like it's running rich, no adjustments to the fuel controler make a differance at this point but the problem clears up over 6,100 rpm.
No matter what is changed or adjusted the same issue arises. Changed box's (actually tried 3 differant fuel controllers) traced wiring looking for a chaffing, checked vaccum with a gauge and there doesnt seem to be any leaks.
The sled ran great last year and early winter, the only change was the addition of a gunnar tether. I read about guys having issues so I checked and found mine had shorted, I thought this was the issue but the sled is wired back to stock without a tether now (I am going to put one back on after fixing the stutter issue).
No codes flash, nothing else seems to be out of the ordinary.
Any ideas would be appreciated, heading to Revy next week.
Thanks,
Y
Thanks,
Y
