If you are blowing belts on your XP Chassis Snowmobile, there is a good chance your clutches are not aligned, even though they will be in tolerance to BRP's measurements. Most have found by moving out the secondary 1.5 to 3.0mm will solve this problem. Since the QRS clutch is married to the shaft, you need to shim both the clutch side bearing and the gear side of the shaft. My kit comes with two 1.5mm large shims for the bearing hosing (clutch side) and two 1.5mm smaller shims for the gear side of shaft, all precision cut out of 304 stainless steel. This gives you two choices to shim, either 1.5 or 3mm, depending on your situation. I do not recommend going over 3.0mm due to it would be pushing the bearing out of the tower too much. If you need more than 3mm you have a more serious problem and need to look into motor mounts mods or a complete floating secondary, which is expensive.
I have personally did extensive testing since 2009 with many different belts and clutch set-up. I’ve sold many kits and have had only positive feedback that this inexpensive kit save others hundreds on belts.
Installation is simple with the use of basic hand tools. Instructions will be emailed to you in PDF format. Cost is $30 with free shipping to US AND Canada. Please contact me with any questions.
Fishon1066@hotmail.com
