I just bought a take off front end from a 2013 Summit. The ad listed the parts from the S36 kit that fits the XP etc.
Replaces prior part number 860200557
SKU# 860200799
1 505073039 LH lower arm
1 505073040 RH lower arm
1 505073013 LH upper arm
1 505073014 RH upper arm
8 250100088 M10x1.25 nut
2 505072923 Front HPG shock
2 505072726 Spring-painted
2 503192608 Spring stop
4 233201414 M10x1.5 nut
2 505072682 Lower ball joint
2 505072913 Upper ball joint
2 293370035 Circlip
4 250100089 M12 nut
2 233261416 M6 flange nut
2 n/a Tie rod assembly
4 232500416 M10x1.5 nut
2 293370070 Circlip
When the box arrived i see a set of shocks that are not that part number. The part number is HPG 505072935 which is a 16.5 C to C shock. I dont see this part number on any 2013 fiche. Does anyone have an idea what this is off ?
Update: I think it is off a 2012 Summit S 600 HO. If thats the case will these shocks even work ? The item was obviously misrepresented ???
Update: Somehow i missed it but the shocks also fit the 2012 SP 800R. So i should be good.
SKU# 860200799
2 293370035 Circlip
4 250100089 M12 nut
2 293370070 Circlip
