RX1 Oil Leak HELP
I have a 03 Turbo RX1 it is leaking about a 1/2 a qt of oil a ride I can only see fresh oil just above the oil pan and all over the oil pan bolts? Could it be a oil pan gasket?
It could possible be the valve cover gasket, being turbocharged. Your adding more pressure to the crankcase. What type of turbo kit? Is the breather wide open. What side of the engine is leaking, front, rear, side, etc.
OIL LEAK
I am running a GT25 on about 10lbs. The top of the motor is clean. The oil looks like it is leaking from the oil pan gasket it just does not seam like the oil pan gasket would leak?
I had a stock RX1 in my shop last year with the pan gasket leaking. Out comes the engine unfortunately. Good luck. Shad
