forgot one thing
I forgot the other huge necessity you would be greatful for doing. Yamaha valves there shocks with ancient pyramid,single stage valving which SUCKS, they work great on little bumps but not big or vice versa....terrible ride on all there sleds. Why they haven't figured this out after all the years is the million dollar question every Yamaha owner wants to know! It cost about 60.00 per shock to send them to Carver Performance and have "Mike" revalve the shocks with multi stage progressive valving for your weight, like Polaris and Doo does with there shocks. This makes for a soft plush ride in the small and stutter bumps, a more progressive ride in the moguls and even stiffer for the big drops or jumps, this will make the RX-1 ton fell much funner to ride. Have them shim the shocks down 3/4" also this makes the front ride flatter and stops some of the body role in corners etc, makes it feel less like a heavy four stroke. So in conclusion, #1. Wildchild rider forward mod, about 200.00
#2. revalve the front shocks and the farthest back rear shock, then pull limiter straps up one or two holes and give your self a lot of transfer by screwing the transfer rods/nuts down. This will make a much much better riding , comfortable sled. You will not know it's the same maching after these two mods, your back and kidneys will thank you!!
After this begin looking into "Kachess" posts on Totallyamaha to see all the other area's you can improve on.
