rx1--how big can the riser be
How high can i go with the stock cable and brake line on rx1? Looks like three inches would work but any one with previous experience please tell!!!
thanks
I went three inches with a wildchild rider forward kit and so far so good but to be fair I haven't gotten it all put together yet.
I did quite a bit of measuring beforehand though and 3" should be fine, especially if you go forward since that's the direction the cables/wires go.
You can sneak a 5" riser in there if you tilt the bars far enough forward.
You will have to re rout the brake-line in behind the coolant tank and my e brake is of so not sure about that but the rest is no problem if you try hard enough.
