RV battery ???'s
B
bullfrog123
ACCOUNT CLOSED
Need to get new batts for the camp trailer. But, I want something that will hold charge for more than 6hrs (current ones are only 2yrs old):mad:
Optima blue top or...............
Thanks.:beer;:beer;
Volt all the way
Buy two deep 6 Volts make 12 and you will be happy. Just hook pos to neg on one battery and the use remaining post for you 12 V system.
Their is a post on hear some were about batteries
CAT batteries are what we use, very tough battery, need to get it from your implement dealer tho. Also had good luck with our interstate batteries, had some in our boat that ran the inboard and the trolling motor, lasted over 8 years!!!!
Just did the same thing you're doing... found the best deal on 6 volts at Costco... 75.00 a piece plus core. Ran them all weekend without any issues.
I checked with a lot of different RV companies and forums and this is where they told me to get them.
Ok..... I have read chit till I'm dumber now than yesterday on this topic:o
But How in the HE!! does 2 6v take the place of 2-12v. Capacity and storage of amps/volts etc seems to me that the 2-12v's would be more;);)
Talk to me in normal voice... not scientist terms;)
Thanks again for the help:beer;:beer;
It just does :face-icon-small-win
What happens in my boat with a 24 volt trolling motor? I am sure not going to wire up four batteries.
I went on Cabela's and read the feedback on some batteries. There was a bunch of people warning to stay away from Optima batteries. They said many were failing in less than a year.
What kind of warranty does Cat have on their batteries?
Someone can explain it better then me but 6 volt batteries can be drained and recharged more times and I have longer amp capacity over 12 volt batteries. I had a camp trailer a for 11 years and ran the 2 12 volt trojans for 4 years and when I replaced them I put in 2 6 volt batteries and the trailer still has them... makes them 7 yrs old and still going strong.
The 2 6volts wired to become 12v become a bigger gas tank in essence than a 12v. That, and like was said already, the 6v batteries are made to be drained repeatedly and won't break down over time like the 12v's do. You don't get any stronger juice out of that setup, just alot bigger fuel tank....I know guys that have 4 6's wired in and can ran lights and furnaces all weekend in the Ak winters and not have to recharge them. Costs a little more up front, but way cheaper and nicer in the long run.
Are you comparing 6 volt deep cycle batteries to 12 volt deep cycle batteries?
I guess something to keep in mind is that voltage is only a measurement of electrical potential.
Battery Ratings..
This might help the whole 6v vs 12 volt thing.
If talking all the same technologys, the size of the battery represents the capacity of the better. Note, I am talking energy capacity, there are normally ratings of amp-hours for a specific amperage (Current*Voltage integrated :eek::p over time gives you energy)
If the 6 volt and the 12 volt are generally the same size, they both have generally the same energy content. Since they have the same energy content, and if we assume they can provide the same amount of power (Current*Voltage), in order to have a reduction in voltage from 12 to 6 you will see an increase in current from I to 2*I.
As compared to the 12 volt battery, the 6 volt battery has the ability to provide twice as much current. Problem is, is that it is a 6 volts, which is not very usable. You put two 6 volts in series to give you 12 volts, you now have a 12 volt system that has twice the energy of the single 12 volt battery.
Have you guys looked at RE (renewable energy) use batteries? I know Trojan makes some very pretty red ones... but dang if they aren't expensive. Probably last a long time too... as they say you get what you pay for, but sometimes you only get a big bill...:beer;
Trojan PDF for information... note the comparison of the 6 volt vs. 12 volt for the same weight battery. Close to 2 twice as much, but not exact.
Go with the 2200, 2300, or 2400 (each a little better than the last) golf cart battery. Like Ruffy said the 6v batt has more surface area on the plates and have a much larger amp/hour rating. Wire two in series to get 12v. I have 4 wired series/paralel that I got as blem's from Interstate for $47ea and can go a full weekend in the winter.
I will recommend the 2 6's in series as well..also..buy interstate batteries..they will last far longer then others, just because they are better built...
I agree!
But I cannot back it up with any scientific mumbo jumbo or any fanct shmancy "facts"!:p
But whenever I get a battery for anything, I buy an Interstate.
I know I am usually paying more than I would for something else, but I simply have never been dis-satisfied with Interstate.
NEVER buy "blems" or "seconds".
I've tried that route, and they are true s h i t!
Another vote for 6's wired together for the same profound reason-it works. Cat batteries are great, also no complaints with Interstate. I have had some problems with the Optima gel bats but if you're going to be running them in the cold a lot the gel bats are better, maybe not optima. The golf cart batteries last forever but unless you need a ballast and have someone around to help lift them -don't. You can get Cat batteries at any Western States dealer. Locations here:http://westernstatescat.com/ContactUs/Locations/Pages/default.aspx
have 4 deep cycle 12 volt in motor home now, will be pulling them out this fall,,,,( 1 yr old ) and putting in 4 6 volt golf cart batteries, just will last longer and give better power,,,,,,,:face-icon-small-coo
