running way to rich
Hey guys fired up the sled took it for a quick burn and let it idle then all of a sudden it starts to idle low and the only way i could keep it running was to the run the throttle myself. And the smoke cloud starts so wondering failed oil pump or check? and the oil level is already way past the crank lubricator point.
check your oiler cable first
if it breaks the pump defualts into wide open dumping oil in your crankcase
oil level is already way past the crank lubricator point.sound like the two oil seals that are in between the crank are leaking fill oil back up and see if it goes down again. if it does that is what it is.
