Sodahucker, I'm not sure you got your answer so I will offer some info on stators/alternators/generators. I am fairly certain your bike uses a permanent magnet stator/generator as do most bikes. In this system the magnets spin around the fixed stator/armature. The output of the stator is determined by the number of conductors/windings and the speed and strength of the spinning magnetic field. Unlike your automobile,where the strength of the magnetic field is regulated/changes with the current flowing in the field windings, the strength of the magnetic field is fixed in most bikes. So, the output of your stator is constant at a given rpm. The output is constant and what you don't use for lights etc is dumped to ground in the regulator. So by running that 45w grip on your 30w stator you use all the output and none gets dumped to ground. if your bike has neither a battery nor efi there will be no negative. if the stator puts out 30w at 7000 rpm it always puts out that 30w. it can be used for the grips or dumped to ground. Unless there are diodes in the ame switches they will work on both ac and dc. It is a resistance element like a filament in the light bulb. Sorry so long.
