running boondocker pump gas w/o EBC
I have a m 1000 turbo boondocker with no EBC or intercooler. I am waitimg for the EBC and components. I have the 1000 fuel controller and the boost regulator attached to the waste gate. This regulator is the one which screws in and out. My question is can I run the sled in this configuration?? How should I set this regulator up?? Should I screw it in all the way or leave it half open? Do you recomend getting a boost guage??? I also have no ADA wiring or harness yet so it is pretty simple.
If any one could give me some help I woulg greatly appreciate it?? It appears that the EBC is never going to arrive and I am tired of waiting and just want to ride the damn thing.
Thanks
You can't run it without either the ADA harness and boost transducer, or the EBC. Otherwise your box will not know when to add fuel for the boost. Also, hooking the hose from the charge tube directly to the wastegate will give you screwed up boost. I am not sure if it would be maxed out or way low.
Sorry man, you are stuck at the moment.
