Rt 1000
I need to locate a 15 plate chain, and sprockets. Sprockets are 21 teeth top and, 49 teeth bottom. These are for an 06' summit 1000 highmark. Any help, feedback is appreciated.
Where are you located at?? 13 tooth seems to work just fine on these and if you are mountian riding with this--You probabley want a 20 tooth upper gear to help cool the clutchs and make them work better.
Just my experiance.
H20SKE...
goto www.goodwinperformance.com you can get top and bottom gears there...
13W is not good for a hardcore rider...lots of 13W break...
goto a 15W and 21/49 is stock...lots of people are switching to either 19/49 or 20/49....and a 15W
start with a 20T top gear and see how you like it...lots more low end and cooler clutches...
get a 20 Top 15W and a new chain 15W and you can use your stock bottom gear that is 13W....
talk to goodwinperf and see if you can get a 20T top gear with the inner groove in it...if you can get one of those then you do not need the 440 spacer...if not then you need a 440 spacer...they will tell you all that anyway..
the reason you need the spacer or the grooved top gear is to center the bottom 13W with the 15W top gear and chain...
Stiff
You can buy ski-doo original for 07 summit 1000, that is 15 wide and dont need the spacer.
Just buy the 15 wide chain and 15 wide top sprocket and thats all.
Thanks guys! I'm checking into both options. Anyone else have thoughts on this? I've bought CS pipes into 1 muffler, any suggestions on what kind of controller to use for these pipes? AND, what map to use as a base to adjust from? I'm on the W.coast and ride from 5-10,000ft.
The Boondocker 4 injector box. Period!!
I have 19/51 gears in my 05 with CS pipes, I have and really like the Boondocker box. I would also go with the 15 wide chain. I haven't had any issues since I changed chains.
Just my experiance.
H20SKE...
Paul, have you pulled your 13W chain out and lookeed it over. I did last summer at 1000 miles and the chain was noticably stretched (held next to new 15W, same 86 pitch). One link was hanging upwhen I rolled the chain by hand. The top 21T gear had lots of wear marks.
I consider myself lucky that the chain didn't break. Put in a 15W .
