So does the sled need to be running at the time of testing?
My problem seems to come and go. But is there more than not. When it is acting up, it doesn;t want to go above 5000 rpms without a backfire through the pipe, exspecialy under a load. Seems as if it is over fueling, due to the fact that when riding it and it pops enough it will catch fire, seems as if it is in the pipe.
but for a short time it might come to life and run fine.
I have checked and replaced everthing but the stator and the TPS.
reeds, vaules, fuel pressure, ecm, all other sensores, compression, I have even put the stock domes back in it, relays, checked fuses, plugs, battery, low pressure pump, everything seems not to change.
TPS is the next best thing to try, without having to colpletly pul the motor to change the stator, Plus i have not an extra one of those .
I am trying to diagnose this problem without the cost of having to buy all these parts.
a buddie has loaned me all the other parts and nothing has changed this problem, Do you have any other ideas maybe???
Thaxs Shad.
