RSI hand warmers - wiring?
dejoli
Putting on a set of these warmers. When I bought the sled, there were no hand warmers on the RSI bars, so there are no wires up to the bars.
All of the wiring instructions that I can find, seem to assume that you're just replacing existing warmers and wires are present.
Does anyone know which exact wires I'll need to splice into?
I've traced what I could, but there are like 5 or 6 unplugged connectors under the cowling and none match the color codes that polaris and RSI state will be the polaris colors.
Any insight would be appreciated.
In the OWNERS MANUAL DOWNLOADS at the top of this section, look for your sled model, download it, as it contains the wiring schematic.
Hope this helps
Maybe I'm completely missing something but I do not see any schematics. I had looked prior there too. The color codes that the RSI provides and what others have stated should be, are not there. There are a couple of options for where to potentially wire these too and was just hoping someone would have some insight if having done this previously.
I checked here is the plugs under hood. Blue, blue red, brown. The wires are the same color on the sled male plug side too. ImageUploadedByTapatalk1360198109.482075.jpgImageUploadedByTapatalk1360198127.893689.jpg
Thanks. Found mine after pulling the wire ties off to get the harness out farther. Partially what was throwing me off was that my "blue" wire looks VERY green at the plug. After undoing some of the tape, it is clearly blue.
Appreciate the pics.
Joe
