At what Rpm does the 800 pull the hardest at (stock)? I've heard some guys saying these motors like to be loaded heavy and will clutch for about 8000-8100. Would like to hear some opinions on this.
i also find 8050-8150 under load is best i usually shoot for 8200 that way under huge load u will drop into that 8100-8 ish range but been running mds weights and find the rpm to be way smother and more bang on sled was hitting 8050 all day
Question about clutching on my 2011 pro- I don't know much about clutching but i raced a buddy the other day who has a stock '12 and we were about equal; problem is, i have a PA head, Fastrax clutching, and a BMP can.
When you guys are talking about pulling at 8,100 or 8,250 RPM's or whatever, does that just mean the max RPM's you are hitting when pinned? As long as the belt sits on the secondary at the right height when stopped and the track barely creeps when the sled is suspended then theres not much else to do right? Any insight would be helpful as I know the proper clutching is VERY important.
152 hp at 8200 rpm on dyno !!!
Mines pulling 8050 with an hps can at altitude ( =
It's running pretty good I think
I run a full porting and clutching package from fastrax. Curts never done Mr wrong when suggesting which direction to go. There is several ways to achieve the goal. I suggest ya pick someone ya trust and listen to them about how to clutch your Sled. You running mtx weights? You could lighten them up....drop your finish rate in primary spring...change helix. The forum is good to learn how this stuff works but you would go broke listening to everyone trying different setups.
