Clutching, with the momentum as you get going the clutching works, but as it levels off the secondary keeps trying to engage farther not letting it backshift. You can drop weight or stiffen the secondary spring. But I would bet if you put new spring in it would be gone, I have seen loses in spring rate in less than 500 miles, so if a new primary spring is stiffer than the one your running it would be just like dropping weight and same effect in the secondary.
