Ok so I have a 14' m800 and I have been struggling to figuring out what is causing my rpm to drop off. When I first hammer the throttle it goes right up to 8300 then if I stay on the throttle it slowly starts dropping rpm down to about 7900 after 4-5 seconds. I have checked my motor mounts(seem good only 1500 miles on cat) inspected clutches multiple times, put in new reeds, checked turbo for excessive wear. I haven't checked for boost leak because I cant find right fittings but it does seem to keep boost on gauge at 7psi the whole time when rpms start dropping off. Is it possible I have boost leak bad enuff to drop 400 rpm when it holds 7psi steady when on the hammer? Anything else you guys can think to check or try?
