Rox Handguard Mounts on 07-08 M series
T
TheBreeze
Polaris
Has anyone used these Rox billet aluminum mouts on a 07-08 M series? I so, how did they fit? Am I better of going with the arctic cat mounts? If so, will the arctic cat moutns work with a set of Rox/Powermad Handguards. Pics?
Go with the Arctic Cat or Black Diamond Mounts. BDX makes the A/C ones. I have those with the Powermadd h/guards. Works well and the h/guards are in a better position.
I have the Rox on my 07 M8. I really like the look of them. I had to mount the brake side a little different. I had to put the bracket on the left side of the switches (when your looking at them) Then you mount it a little different with the threaded bolt that is supplied. Everthing will line up ok so when you look at it from the front they are even. I attached the best pictures I could find but can take some more if you want.
i run the ac ones on mine. they bolt right into the hand control mounts so you don't loose any space for your controls/hands. don't know if any other handgaurds will fit these mounts
I used the ones that come with the powermadd kit. I removed the rubber stops in between the grab bar and the controls and used a cut off wheel on a air hose to cut a pice of the controls cage plastic so it mounts flush with the controlls but using the LEFT hand braket for the right side. and repeated on the other side. works good. However i am not impressed with the powermadd handguards them selves the plastic mounts that the bolt goes through is just a joke im going to have to buy a new set before next year other wise it covers up my brakes. NOT Fun
