Rox flex tec 2
Does anyone know if these are available yet? There are two different mount options, standard and hillclimb, which would be used for the pro taper bars? I know there are clearance issues on the brake side, it sounds like just some grinding to the mount.
Get them and let me know. I want these same handguards. Will be running them on fly bars but probably mount the same.
From what I understand the hillclimb mount is for cat only.
Guess that the only way is modify polaris pro taper mounts, if anyone have made this I would be greatful for pics.
use the pro-taper mounts for flex tec's . their mount does work but not nearly as good as the pro-taper mounts ! trust me
Flex tex on Pro Taper bars
I talked with both Rox's and sled solutions. Rox told me that they don't know if they will be able to get their FlexTec mounts for the Pro Taper bars this year. Said they have a lot of irons in the fire. Sled Solutions told me that they should be coming out in November. That was from Paul yesterday the 16 of October.
