Recently switched to the snow bike world. In the sled world rotating mass is one of the big things people are going after to increase performance. Lightweight clutches.. brake rotors. Anything that spins.. what's out there for bikes? Anyone dabbled in this yet?. I'm on a 2011 ktm 450sxf. 16 Mountain horse short track. Can't find many power adders for my setup. So why not do what's seems pretty proven for those guys?
For your kit to make it more efficient:
You NEED THE LATEST TRACK thats the first issue to make a better snow bike
Then you REALLy need to upgrade your ski/spindle to the ARO. After these two upgrade you might consider it perfect.
But
If you have the time check out the rear idlers ( they are not round )l land often spaced to rub on the drive lugs, the top idle wheels ( they also are not round ) are likely rubbing on the track drive lugs, are toooo wide and need trimmed or replaced........need to make necessary adjustments, check your drivers, they most likely are also rubbing on the drive lugs unnecessarily and need to be spaced correctly.
If you have stock springs on your shocks.............they are way to soft !!!
If you walked alongside your uphill climbing track/trench you will see hard piles of snow every 50 ft or so, your soft suspension is compressing from traction and letting go over and over and you are going nowhere very fast.
Better chains like DID DVX are more efficient and seat of the pants and easier roll.
And if you pull up all the TS threads since your 2016 came out, lots of help on making a lighter better kit.
There's a month of evening work.
