Will this drop in piston kit work with a pa head? Thats what my sled is running now.
It would require new domes. I would sell that head and get the complete drop in kit.
I have the drop in kit in one of our sleds and it rips.
the drop in kit is different from the the replacment pistons kelsey sells.the pistons have a lower dome height than the regular pistons,so to get your compresion back you need a different head.i don't think you could even run this head with stock pistons
The drop in kit is in fact a different piston than direct replacement piston. The drop in piston changes the port timing and has a different head to match it which equates to more hp.
Why spend a great deal of money on mods !! But not on fuel ? Det is 90% fuel , but not always. I think vendors sell HP ! Pump gas big HP , and fuel controls , maps ??? Ect! Why not start out with a new set up , 95oct & back into it rather than Det , surprise ! Just a thought !I have two different kits at home for two 2012 155 pro's. One kit from RK Tek, Pistons and a 13.5 head and one from Terra Alps with pistons shim and 13.1 head. My thoughts on the kits before install.
- Heads - Both heads are very nicely machined no fav here! Now turn the head over without the domes installed and I'd have to say I like the terra Alps head better. Reason being I don't like how the RK head has such a large area for the coolant to hang out in.... (pressure and flow theory)
- Domes - Straight up going with Terra Alps on the domes... Hard to get into detail on this because I'm not going to get my pecker slapped for giving out to much info on each part (sorry).
- Pistons - Each piston is very different in size which should make for a very different running engine do to different port timing. Wossner pistons are very nice OEM pistons are well OEM. Weight between the pistons are very close....
- Shim - Only from Terra Alps and looks like a shim
- Other notes - No pin bearing from RK Tek, wish both kits come with new o-rings for the head install. Sorry but I'm not going to give out any pics of parts or any measurements. I head back to work tomorrow so the install won't be complete until the first week of Jan. I'll be on the snow that weekend and I'll be back with a full report. This is a straight up comparison I felt would be cool to try out......... To be continued.........
I ran the kit as posted above and didnt get 100 yards from the truck and sled was DET and bogging at 6500 RPM AND UP. i RUN A 11 PRO WITH NON ETHANOL GAS. Went to my shop and swapped heads back to stock and went back up and sled ran perfect with stock head and rk tek direct replacement pistons. Im gonna call kelsey tomarrow and see what he thinks but it deffinitly leaned it out way to much.
