05 800ho fouls plugs off idle & idle.
Mid & top end runs good.
If I lean pilot screws it will get lean bogg off idle. Started with 20 pilots 2 1/2 turns and leaned out, went to 17.5 and ended up at 3 turns out for best response. Lean stumble when trying to go in on screws but plugs show wet and black and will foul quickly. Running 360 mains, needle clip in middle slot, stock exhaust & stock can. Riding between 4000 & 6000 elevation.
Tried 1 notch rich and lean on needles with screw adjustments but no help.
Whats the trick to adjust pilot screws, can it be done while engine is running?
