K
Kestrel2126
I just pulled my motor this summer on my '11, after 400 Break in miles, and right at 2000 under 8-12 PSI of boost. Last season, I was on the verge of doing the top end, but decided to throw caution to the wind and ride it til it blew. It never did, and I finished out the year. When I pulled the top end, I expected carnage. To my amazement, things couldn't have looked better (on the top end). Cylinders were clean, no stress cracks, good nicasil, and no scarring. Pistons were also in great shape. No scarring, great wash, no sign of DET, although the rings were definitely worn, they were not flaking.
Anyhow, I already new which way I was going for my top end, and sent the crank off to be rebuilt and balanced. I just found out the other day, that the motor was in fact getting close to grenading, but it was due to a lower bearing pin starting to walk out. I guess I got lucky on that, but was really surprised at how well the top end had taken the abuse.
So, this year, I'll have a fresh motor, that will hopefully be solid for another couple thousand boosted miles. And in a study of making two people that completely disagree (this is a major understatement), unknowingly work together, it will be on an Indy Dan bottom end, and an RKT top end. HAHAHA. Both of these guys are great to work with, are extremely knowledgeable, and build EXCELLENT products, regardless of their difference of opinion.
Dan rebuilt and balanced my crank, cleaned up the cases, balanced and shimmed my clutch, and checked and reinforced my cylinders. The motor should be in transit to me now.
Kelsey built me a custom head for my elevation and boost levels, as well as supplied me with a new set of matched forged pistons, to pair with the head.
I cannot wait to get this motor back in the sled and started getting my tuning dialed back in, so I can tear up the Colorado high country.
Thanks to both of these guys, for building great stuff, and at least on my sled, you can both get along!
