I had an 05/400 sled with a bone stock 03/800 engine and ran it on the dyno.
It made 136.7hp at 7850 rpms.
Put the drop in piston kit on with ecu curve and calibrate jetting 2 sizes rich, plug and gap, and made ring-end-gap as kelsey mentioned.
Ran the sled for some miles dialing in clutch for a few afternoons then went back on the dyno.
Dyno revealed 144.5 hp at 8300 rpms for increase of 7.83hp @ 390 main
Went to 370 and dyno showed 146.1hp for gain of 9.47hp
I ended up running 1 size rich than recommended because sometimes I have to mix in 89 octane and there are a few places in the backwoods where I can be full throttle for 30+ breaking trail if I wanted.
So for me it delivered a pretty big smile on my face after seeing even 7.83hp gain, an excellent $/hp ratio.
Oh...and I used the stock suitcase muffler as I like quiet.
Here is a
clutch kit customer of mine running the RKTPDI in his 08 (late season in Sweden) rev's like 8300 sounds good)
Calibration if I remember right is...
200/350
21 grams
413 ramps
clicker 4
QR11 helix
19:45 gearing
I get my customers with 800R engine to run same clicker but one gram lighter pinweight to go from 8150 to 8300 or can take do nothing else in the system except take the primary spring final force and raise it 30 lbs.
I submit, follow kelsey's guide on engine calibration, then clutch calibration will be quick to change to satisfy achieving correct rpms.
