Anyone have a RK TEK 925 Big bore on there M8? What are your thoughts and opinions? What do you like and don't like? Did you get the secondary clutch kit also? What about just the porting kit and billet head combo as well?
AK thanks for the reply. I've decided to go with just the porting and billet head for now. I'm also looking into more info from cpc, bikeman, speedwerx and rk tek. I think itll be rk tek in the end though. What are you going to run for a pipe? Im going with a full slp kit, boyseen rad valves, pc v, and most likely a full clutch kit from rk tek. What are the octane requirements for your setup?
blackjack...from all that i started to read and all that you were going to do to the sled, would it be cheaper and easier to just turbo it?
M7 thanks for the reply. I think im going to hold off on the big bore for this season and see how it runs with just a bolt on setup. Where you ride at? What altitude? Im riding in southcentral alaska from 0-3000 ft. What are your octane requirements with your setup? What can you going with? Let me know if you find the speedwerx pipe easy to tune or if it requires constant tuning. I've heard different responses about the speedwerx pipe and how consistent it is. I'm interested to hear how your set up turns out and what you like and don't like. Thanks
