1500 MILES ON BOTTOM AND 550 MILES ON TOP
13.3:1 DOMES PREMIUM PUMP GAS
BASED FROM 700 CYLINDERS SO NO SLEEVE
NO STATOR/FLYWHEEL OR CARBS AND REEDS
HAS OIL AND WATER PUMP
DUAL RING PISTONS
THIS IS A 150 HP MOTOR!! RUNS GREAT
I HAVE JETTING SPECS TO PUT YOU SPOT ON FOR LOW ELEVATION
WITH THIS MOTOR AND WELL SET UP CLUTCHING YOU WILL BEAT ALOT OF BIGGER SLEDS!
I WAS AT THE WEENIE ROAST RACES THIS PAST WEEKEND IN WI AND WAS RACING 15 SLEDS WIDE ALL DAY
RUN DEAD EVEN WITH NEW 800 E-TEC.. RAN FOR PRY 1500 FT
BEATS STOCK F7S F8S AND EVEN M1000S 700 AND 800 POOS, APEX'S OTHER MEMBERS HERE TO VERIFY THAT
I FOUND IT WILL NOT RUN WITH BIG JOHNS PERSONAL 860 THOUGH... LOL WE THOUGHT IT WAS FUNNY THOUGH WHEN THE 2 M1000'S WERE BEHIND US!!!!
AWESOME PUMP GAS TRAIL MOTOR. USE STOCK 600 H.O PIPE AND MPEM
THIS KIT IS $2195 FROM RK-TEK AND THATS WHEN YOU SEND YOUR PARTS TO B MODIFIED... THIS IS COMPLETE!!!
CURRENTLY MOTOR IS IN MY 06 440
ALSO HAVE AN SHR 700 H.O. MOTOR BASED OFF RS CYLINDERS RK-TEK HEAD DUAL RING DOO PISTONS SAME PERFORMANCE/RESULTS
$1850 FOR EITHER
JOSH
DUAL RING PISTONS
$1850 FOR EITHER
JOSH
