Finally got to ride the new 858 this weekend. Let me tell you this thing pulls hard. I started with Kelseys REV 2 fuel numbers. I had a real bad rich bog after 7500RPM. Wouldn't even pull itself through it. I pulled 1-2 numbers from everything over 7250 on the boondocker box. Seems ok now. Gonna do a few plug chops after i get a few more miles on it. As far as clutching i installed Rooster weights with a 150-340 team spring. Ended up at 9 grams in heel 3.5 in the middle and 2.3 in the tip. I am thinking i may have to add another gram once i get the fueling dialed in a little better. But right now it will tach 8450. What is everyone else using for fuel numbers on these? Here is mine so far. Also my tps min and max seemed out to lunch but? 52 MIN and 219 MAX?
Updated fuel numbers Jan 26'14
2500: 00 00 00 00 00 00
4000: 03 03 03 03 03 03
5000: 04 04 04 04 04 04
5500: 04 04 04 04 04 04
6000: 10 10 10 10 10 10
6500: 10 10 10 11 11 11
6750: 08 08 10 13 13 13
7000: 10 12 12 13 13 14
7250: 09 11 12 13 14 14
7500: 09 11 12 14 14 14
7750: 08 10 11 13 13 13
8000: 10 12 12 16 15 15
8500: 11 13 14 17 17 17
