risers for the 08 M8
D
dcturbo
I looked thru the search and never really found,
What's the best handlebar riser for the 08 M8????
Do you have enough brake cable to get a 2-3" rise?
Any other issue to be concerned about?
thanks for the help
DC
This is what I have seen. 2 inch no problem 3 inch is close but you can route cables little different to make it work, but close.
Riser
3" will work fine, but you will have to cut the zip ties around some of the cables to loosen them up. Once it's installed you will have to zip them back together in their new positions. You will not be able to put the cover back on unless you mod it. I can't remember what brand I used, but I have done the 3" on three different 08 M's.
Jensen, Is that what you have on your sleds now? I would love to come by and look and sit on your sleds if possible..
Thanks DC
