riser?
Ive got a 2in block on mine and theres not enough room to go higher, im buying extensions and an 8in, its not a big deal installing the extensions just$$ and that extra height makes a huge difference in the way the sled handles
People have run our 3" Angled Riser with stock controls. Depends on how wide you run your controls but our Angled Riser raises the bars straight up. The block style will move you back on the sled, pull more on the cables, and not give you the true inches of rise.
Snowest members get 10% off of entire order. Discount code ad445d
Thank you,
RSI
Safely you could run a 3 1/2 inch riser. I Running a 3 inch is extra safe.
HOWEVER, you then run into issues with the steering post bending. On these sleds the steering post was a big time weak link. I used to cut mine off and run a solid rod down in it then weld it back up for strength. Now days I make posts out of titanium.
