Is it normal that all my stock wiring on my 07 D7 goes through the center hole of the stock riser? I was hoping for "plug and play" as mentioned above but it looks like everything except the brake line has to get disconnected.
Unless you plan on re-using the original riser, you can just cut a section out of the middle, and all the cables and brake line are free. No need to to disconnect anything. Then install the new riser and run the cables on the front side...plenty of length and no binding at full turns.
07 & 08's have same cables & hoses but risers are different. I'd like to go to a 7inch on my '08
2007 Dragon
5135350 Block, Handlebar, Riser, 3.75 Inch
7081332 Cable, Throttle, SDI
2202929 Kit, Hose
2008 Dragon/RMK
5135884 Block, Handlebar, Riser, 5.25 Inch [600/700 IQ Dragon]
2202929 Kit, Hose
