riser help fast
i would recommend putting on a Pivot style riser, it will help you stay more in the middle of your sled when riding and wont push your bars straight back into you. I have done both ways, a pivot style riser and just a normal block riser, trust me go to the pivot style.
2 ways to do this.
1.) you can just buy the Pivot block adapter to make your handlebars a T-bar, than you can get any Polaris or Arctic cat Pivot style riser block, they have the same bolt on measurements. Than you can put on a 2 in riser block without having to get longer cables. Any taller than you will need longer cables, I have this on my 94 XLT, but I have a 4.5 riser and had to put on throttle extension and brake cable.
2.) You can cut off the flat mount on the end or steering post and weld in a piece of Stock steel round to the top of your steering post to make it a T-bar mount like on all of the new sleds. Than you can get a pivot styel riser and should be able to go up to a 4.5 riser without new cables. This is what I have on my 92 Indy 500.
I changed to this style of handlebar:
http://cgi.ebay.com/ebaymotors/Pola...wmobile_Parts_Accessories?hash=item1c0e7e730a
It gave me 3" of rise over my stock handlebars, plus added a pivot at the mounting location (you have to have the mounting brackets for them). I got a lot better deal than the ones in that link, I just posted that as an example. I bought a couple pairs with throttle blocks, hand heaters/grips, mounting brackets, and plastic covers all included for about what those are going for.
I added another 2" true vertical riser under the pivot on mine. A true vertical riser is angled on the ends and lifts the bars straight up.
http://cgi.ebay.com/2-POLARIS-SNOWM...wmobile_Parts_Accessories?hash=item27ad8ff776
riser
I put an 8" riser on mine, wiring was long enough, no issues. new brakeline and throttlecable extension though. works good, I'm 6'5".
