Is there a riser block available for the Apex that goes on top of the existing riser? I would like a couple more inches of height but dont want to lose the stock look ( chrome trim ring)
Sno Pro have 3 diffrent hights, if you only wants to extend the existing riser.
Muffinworks have an excelent Pivot riser that lets you keep the chrome trim, superior quality, and the Pivot ability is great.
You should be able to get 3 inches without a problem if you tilt the bars ahead slightly after the new riser is on and take that black metal piece off that groups all the cables together.
I used a stok riser block and milled the bottom profile to use the stock chrome ring at the base. Then milled the top of the 2 7/8 inch block that I added to fit the bottom of the stock riser block. Stacked the two pieces together and used 4 pieces of 8mm threaded rod to laminate the two blocks together.Rod locktite to stering post, slip blocks over rods and reinstalled the bars.
