Riot Spindle Kit
boondocker97
4,095
2,833
Billings MT
A bolt on solution for those wanting to run the taller OEM Riot/SX spindles is finally here: https://tkicnc.com/product/tki-upper-a-arms-for-arctic-cat-2018-2022/
Developed by Jason Nethercott and Garth Kaufman (former wrench for Tucker Hibbert and RMSHA racer).
Looks like arms are available if you want to source your own spindles or can add blue or grey spindles. Guessing availability is dictating color choices right now.
gp800
209
206
This kit puts you back to 12-15 geometry just taller spindles. It works well for guys that like to "drive" a sled, they turn great but will have more ski pressure than you will be used to. I also don't feel like this spindle is as happy on edge as the 16+ geometry.
mountain_tamer
105
Rimbey, Alberta
It is not the same geometry as the 12-15 sleds. It is sort of in between the two I would say.
gp800
209
206
The spindle geometry is the same but taller. The caster could be slightly different based on the position of the ball joint but everything I’ve been told says it’s closer to proclimb. Which I don’t believe it’s a bad thing I prefer it in certain situations and use it on my race sled but looking at the spindle on the sled it’s visibly more stood up than 16+2EFBA7AD-3749-4F96-97C7-F1FED00A83B6.jpegD66DC59A-43C8-4953-B3AF-8FE8ACB378BD.jpeg
Chewy22
1,996
1,372
Montana
The spindle geometry is the same but taller. The caster could be slightly different based on the position of the ball joint but everything I’ve been told says it’s closer to proclimb. Which I don’t believe it’s a bad thing I prefer it in certain situations and use it on my race sled but looking at the spindle on the sled it’s visibly more stood up than 16+View attachment 377665View attachment 377666
Seems like you’re making assumptions and have not actually tested this kit? Running the spindle with factory geometry upper arms is not comparable. ?
gp800
209
206
The only difference between what I have and what the kit is Is my sled is 38'' wide. I don't mean to come off as saying this kit is not good in fact feel there are situations where this setup is superior. I just want people to understand what the riot spindle is.
sno*jet
2,830
1,301
Im confused, but in my mind gp800's comment on the caster angle and handling sound about right. more precise steering, less forgiving in sidehilling/countersteering scenarios. hillclimb racers dont run light playful front ends.
