Hi!
Wanted to share this, so you can be aware of this and check your kits!
So, after few rides, there is marks in long arm, hitting to lower front suspension tube, when suspension bottoms out. Looks like this could really make bad damage over time, or once it bottoms out hard.
You see the problem, if you take shocks off and lift front of the rails all the way up. In my kit, long arm hits one of the cross tubes on the rails. Front bottoming rubber did not even touch anything there!
I did wonder this when checking things in this brand new kit before season started and asked what do Timbersled think. They said long arm is not going to hit or make an issue when shocks are attached.
But now, Timbersled have updated MUCH thicker front bottom out rubber to solve this problem. Make sure you have these!
