I tested the wires and they all got power what would cause just this side not to work? All three wires have power .
Yes and all three show power when I tested them?
Ok didnt know that it would show power all the time,and yes I do ,but not sure how to do that with a OHM meter .I believe those 3 will show power even if you disconnect the plug. If you have an ohm meter, disconnect the plug and check the impedance of the heater element.
With the plug disconnected (and the motor not running), check the impedance/conductivity between the leads and ground. The resistance should be more than 0 ohms but less than infinity. Use the left side readings as a comparison.
Yep, just did this a couple days ago. I checked the bad one out and couldn't tell that there was a break, even holding it up to the light
